Underfelt too tight now weather is cold
13 Jun 2007
Evening all, my first post so please be gentle.
Anyway, I'm building myself a garage, 5 x 6 metres, with a pitched tiled roof, concrete block walls. I've designed and built it all myself, using the internet and various sources for info. I've not fitted the tiles yet, as I've been away working, but they are in the garden ready.
So, the problem, I nailed the felt on and battened it in the hot weather in April, and it had a fair sag between the rafters, maybe 1", but I now find it is pulled tight in the cooler weather. When it rains water leaks through around the nail/batten points, as it is getting trapped and pooling because the felt is taught against the battens.
I have a plan to run a length of thin nylon rope down centrally between felt and battens, to make a gap for any water that may leak in to escape down the roof and out the bottom. Any opinions on doing this? is it a daft idea? I really really don't want to pull all the battens off to run the felt looser.
The underfelt is called something like Klober spantech light, can't remember exactly, but it is non permeable.
A piccie:
:oops:
How about lengths of plastic pipe. 15mm should do the trick, and is more likely to stay put than rope. Drill small pilot holes thru batten and pipe and stick some screws in to hold it in place.
Nice looking workshop btw. Did you build the trusses yourself? I am soon to be reroofing my garage and was thinking along similar lines.
I wouldn't worry too much as it's a garage, correctly fitted roof tiles should be trouble free for years.
I just spoke to a guy in the roofing place I bought my tiles from and he said there shouldn't be any leaks with the interlocking tiles I'm using, so my worries might be for nothing. Fingers crossed :wink:
Deluks, I built the trusses in place, but if I did it again I'd definitly buy them ready made, as it would save a thousand trips up and down a ladder building them. It was interesting, but sheer hard work hammering a million nails in and handballing the timber up.
It's cheaper to have it made as the stress calulation will use smaller timber :wink:
Nice pis, thanks for the inspiration.
They look pretty hefty, is it all done in 6x2? Nice storage area too, how much headroom is up there? or is it a case of stick your head up there and shove things about from the ladder?
I cheated, and got a quote, which involved them sending me a blueprint of exactly what they were going to build.  8)
It is all 2 x 6 timber, treated and kiln dried. There is just 4' max headroom in the centre, but ample to crawl about in. I plan to buy plastic wheeled boxes for storing stuff in, so one can slide into every 'slot' between the rafters.
I got some tiles on today, not as difficult as I thought it would be.
Looking grand. Why the glass bricks. security reasons?
Couldn't scan those blueprints in could ya :wink:
I'm still in two minds about whether the glass blocks were a good way to have tough windows, with a bit of insulation and minimal expense, or whether they make it look like a public toilet...... :oops:
Blueprints? I'd have to draw some first mate :wink:
All tiles now on, ridge tiles included. I used the Kobar dry ridge system, which seems pretty agricultural to tell the truth. I also mortared the verges.
Next thing is to look up the 'rendering' and 'wiring' section of this website :D
Well, the roof has been tiled and complete for about a week now, through some of the most horrendous heavy rain I have seen in years in England, and I have just a couple of slight 'runs' coming down the underfelt on the outside, but nothing at all coming inside the roof area itself. Two of the runs are right near the verges, where my rubbishy mortaring has probably left some gaps. Another is just inboard of the gable end, but it is so slight I can't even locate it inside the roof, by looking and feeling inside the felt from the inside, so as long as it gets no worse I'm not worried. :D
