can't agree with the thermal store being better than unvented
the thermal store loses working temperature very quickly the minute water is drawn through it. my experience is the unvented cylinder holds a workable temperature for a longer period.
all the complaints that i have dealt with have been thermal stores that had been installed by 3 now defunct companies i have never been to a complaint about an unvented cylinder
At first sight that sounds like nonsence but I can explain what Kevin means!
An unvented is tall and thin and hot water taken from the top will be at the stored temperature until you get to the last 10% or so when some mixing occurs with the cold inlet water.
The thermal store outputs the stored heat from a coil neat the top or a pumped plate HE and the whole store contributes to that heat transfer.
If the store starts at 80 C then when half the heat has been taken out the store temp will have dropped to just 50 C. At such a low temperature the differential of about 10 C across the HE will mean that the maximum output temperature falls to just 40 C.
We have now only taken just HALF of the heat out of the store at this point! From that point on the transferred heat into the DHW will cause the output temperature to fall below 40 C which may be OK for the washing machine but is useless for baths or showers.
The useable heat output is therefore only HALF of the actual stored heat!
I've had to postpone an install this week, but even though i feel a rough as hell I will still have to attend call outs, which unfortunatley keep coming in Letting all calls go to voicemail and vetting first.
Thermal stores and heat banks are different. Thermal stores have an immersed coil for DHW take off and heat banks a super efficient plate heat exchanger. Heat banks are far better. They do not loose working temperature easily at all. When they cool, the boiler comes in full on and puts its heat right at the top of the cylinder where it is needed for DHW take off to the plate. In effect the energy of the heat store and boiler are being combined.
A plate heat exchanger is so efficient, it can operate at a temperatures only 10C above the DHW temp required. If 50C DHW temp is needed then only 55C is needed in the stored water. They extract so much heat from the stored water and transfer it to the incoming cold mains water that the returing water temperature to the store is around 20C. Heat banks operate at a wide usful temperature range. The lower temperaures at the bottom of the cylinder promote condensing efficiency in boilers.
An unvented cylinder is far inferior in many ways to a heat bank. The boiler connected directly to a heat bank is operting in a far superior hydraulic environment and a natural neutral point and buffer is provided. A heat bank provides many great advantages all in one package. One of the greatest innovations in heating/hot water for many decades. Get to understand them.
Thermal stores and heat banks operate differently in DHW take off and heat transfer.
