Underfloor heating
17 Sep 2009
Nottinghamshire
I was wondering if it is possible to add underfloor heating into a small kitchen running off the combi boiler.
I've seen diagrams on how it would need to be done adding an additional pump, but wondered why this was necessary? There's already a radiator right at the end of the kitchen that runs almost directly from the boiler but it size isn't good enough and there is no wall space available to add a larger radiator and it would allow for more cupboard space in an already small kitchen if I could get rid of the radiator altogether.
There's an ample step down into the kitchen to allow for the raising of the floor for insulation and the pipe work.
Gobz. :D
It may be easier for you to add a hydronic plinth/kickspace heater.
The diagrams you refer to include an additional pump and blending valve such that the temperature of the water in the UFH loop can be reduced to a more sensible level, as the 60-65 degrees used for the radiators is far too high for a floor surface.
