not bother with hangers on the big beam at all?Personally, i would sister the beams and out nogging in. Nice tight fit.
Because the existing are notched over the beam. So half the thickness is missing. As such may also be probe to snapping off rendering the sister useless. Unless you can suggest something else?Why put hangers on them?
Why’s that? It’s not going to stop it flexing. And will add a lot of weight. It’s will stop lateral movement but that’s not the issue.If that was my house I would screw some 2400x1200= 18mm ply to the underside of those skinny floor joist before fitting the plasterboard with a lot of 70mm screws.
Yeh I agree with the faff. Thanks for the suggestions any way. I’ll mull it overIt's either leave it, or perhaps add more of the same size joists, in-between the current joists and use a hanger to connect to the beam.
In my mind though, it will be a faff.
Thanks for the detailed response. I think the first reaction is to look at the size and assume they are too small by modern standards but as you and others have suggested the old wood was slow grown and much better strength.Assuming your floor joists are - say 1800 long (?) @ 500 centres (?) and, being old timber, equivalent in strength to something like modern-day C24 timber, which is better quality than the more usual C16 timber.
The bending stress and deflection of the joists themselves would be within acceptable limits. This suggests that the source of the 'bounce' might be the long beams supporting the joists.
As regards the notching of the joists onto the main beam; the only aspect that matters at the end is the shear stress across the reduced section where it is halved. Assuming it is reasonably good-quality timber, the reduced section is still adequate, but near to the limit of allowable shear stress. It might be worth considering screwing a batten to the main beam (s) along the underside of the joists, to give a little extra support.
But before you do anything with the joists, I'd be inclined to check the main beams first; they may be a little undersized for the span and loading.
Theoretically if you can fix the boards to the beams so it all acts monolithically (lots of screws and glue) then what you have created is an inverted Tee beam which will resist deflection(and be stronger) than a rectangular beam. I did some noddy calcs once and it indicated things were improved three fold but of course it all depends on the particular dimensions used. As for lateral deflection the joists are not particularly slender so I don't think that's an issue anywayWhy’s that? It’s not going to stop it flexing. And will add a lot of weight. It’s will stop lateral movement but that’s not the issue.
Theoretically if you fiWhy’s that? It’s not going to stop it flexing. And will add a lot of weight. It’s will stop lateral movement but that’s not the issue.
Basically dimensions required to give a proper appraisalAssuming your floor joists are - say 1800 long (?) @ 500 centres (?) and, being old timber, equivalent in strength to something like modern-day C24 timber, which is better quality than the more usual C16 timber.
