I live in an old house, built around 100 years ago. Ripped up some old laminate flooring downstairs because I wanted to replace it, and thought maybe I could try and make the floor more even below because I want a 240-litre aquarium to go in the corner of the room. Is it a suspended timber floor, sitting about 400mm above the dirt. The room is 7m x 4.5m with a dwarf wall supporting joists half way, so joists are running 3.5m. They are c. 50mm x 100mm which seems very undersized, at 350mm centres.
The stairs are on one side of the room, along with the hallway which is tiled. I can't really get to the joists that run under these. However, I was thinking of sistering the others to strengthen them and maybe use noggins, or maybe even support them from underneath half way along the span with concrete piers or breeze blocks or something. The joists currently go into the brickwork at the front and back of the terraced house. What is best plan? Ideally, I would like the floor stiffer, stronger, flatter and (if possible) more level! What is the best course of action? I am not a novice DIYer but not experience either. I am on a bit of a budget, and whilst I am happy to get a builder in I can't really afford more than 1k for a few months.
Thanks for help everyone.
