So...
groundworks due to commence on my double storey extension in place of conservatory. Removed the conservatory carpet to see some crumbling self levelling screed and some DPM sticking through. A tap with an iron bar and soon found I have a sealed manhole there.
The pipe runs straight through, but the invert is 1700mm deep. About 3 metres back (and outside of the line of our foundations is an inspection cover at 500IL with some pipes joining from a gully and ensuite.
What is missing is some point at which the pipe drops to such a depth, and also where the SVP from the main bathroom joins. (Yes, I've done loo-paper checks and it appears in the deep one, but not the shallow 1!
Biggest problem is that the manhole is close the foundation line and the room will be a kitchen. Even if I retained the sealed cover, it would be half way under a run of units. As it is a straight through, can the manhole be filled in?
Will I have to have another manhole under the floor whereever the missing joint / deepening is?
The floor will be block and beam for heave protections. Luckily not ordered this yet, how do you incorporate a sealed drain into that?
