Hi there Ive got a dilemma not sure what to do. Ive got a single wardrobe which is sitting on an unlevel part of the floor. the bottom part is 2 inches away from the wall and the top part (which i was going to connect to the wall is just over 4.25 inches away) - i know i have to put a baton on the wall and connect the wardrobe to that but if I do that the wardrobe would lean back - i was wondering if its possible that I could buy adjustable feet for the front to make it lean back a bit and then connect it - or is there a better solution. At present I cant use the wardrobe as Im worried that once I start putting things in there it will tip over because of the weight.
Thanks in advance.
CJ
Thanks in advance.
CJ
