Unusual cylinder
18 Jul 2006
Sussex
Hi
I've just come across an unusual cylinder.
It is a combination cylinder
It has 2 immersions (not Econ 7)
Direct
It has 2 22mm pipes half way up and lower down, that look like some sort of feed and distribution. These appear to come off the mains - v small expansion vessel, tundish & some sort of bypass.
Doesn't appear to have any other hot outlet.
Anyone know what type this is???
Sorry to be vague - never come across it before.
Graham
Make and model, plus a pic would help.
It may be tank in tank.
Thanks agile - yes it's a thermal store
As I don't have an unvented cert. I wasn't sure when I saw the expansion vessel.
All this cylinder needs is one of the immersions replacing, so not a problem.
Thanks again
Graham
yes on the mains cold some have a mini expansion vessel on em seen quite a few.cant remember the cylinder make. think it was mcdonald engineering.
Presumably because the mains cold that sits in the coil becomes hot and expands... I saw a small one on a thermal store also...
As the thermal store is open vented then you can work on them as required without a G3 Certificate.
The DPS Pandora uses an expansion vessel. You can thus install it in a cellar without a drain connection.
