Has anyone installed above. Need to know output of above and what cabling needed.
Also induction hobs, what cable size is required for these? I know i will be safe with 10mm, but will i be able to get away with 6mm. Cable run is 20m.
Also cooker switch is mounted 1150mm from finished floor level and 300mm to right of future hob. What height should i mount output box for hob and should i come back in line with hob?
Thanks in advance.
Thanks in advance.
