Unvented Cylinder vs. Combi
Different houses, plumbers Boilers and water pressure will all see performances differ. Bernard hasn't said to much that is wrong..
Could I ask the experts on here about a Combi Boilers, as I’d love to know more.
Is there much difference between brands? As always, I want to stay with the known brands, but is an Ideal any different to a Baxi, for example? Is there anything I should look out for or avoid?
Likewise, is there any rational behind oversizing the power of the boiler. If I needed a 24KW unit and installed a 36KW unit, does it just mean I get a warmer house quicker?
Any guidance would be appreciated.
Apologies, no idea why my posts keep appearing twice!
If you go for a 36KW you will need good water pressure. Also depending how far the meter is from the boiler you would more than likely need a 28mm gas supply.
Most of my installations I run 28mm gas (even for 24KW)
A bit but it is more to do with the quality of the installation than the make of the boiler in my opinion.
The output on boilers is more to do with the hot water requirement. They are all generally oversized for the heating requirement which is usually much less than the boiler can deliver.
Thanks @Bodd. (Again!). As before, changing the gas pipe would not be a big job, as the boiler is close to the meter.
I must confess, I just made up the 36KW figure (as one of the larger sizes I found) for example. Just wondered if “bigger was better”?
How many bathrooms/ shower rooms do you have
Thanks, that’s really interesting. As this thread is very much about my hot water performance, I assume a large/oversized Combi boiler will give me the best chance of improved showering?
Are Combis smart, in that they throttle back the output? Or do they run at full (36KW, for example) all the time?
It is when the mains pressure drops (*) too low to force enough water through the DHW circuit to trigger the flow sensor to get the boiler to fire up for DHW
(*) due to cold tap(s) being turned ON.
How often in the real world does that happen or is it more theoretical combi bashing?
My point is that if you have 1-1.5 bar pressure (which is what you need as a minimum to pressurise the boiler) the flushing the toilet won't have any effect on the boiler.
