Unvented/ secondary circulation
  • Thread starter Bamber gaspipe
  • Start date
21 Oct 2004
Onetap said:
The DIYers often don't know but, more importantly here, they know that they do not know. They will research the topic, get a book or search the internet to find out.
Again, I think you're grossly mistaken about what lay people think and do. Just my opinion, but I'm not making any assumptions, whereas you're making lots.
Many "Proffessional Heating Engineers" don't know but think that they do know. They get the hump if anyone has the effrontery to suggest that they don't know, as you have.
You'd know about it if I had the hump, so wrong again. Go on - go for the hat trick...
The OP asked a question about something outside his experience.
Now he knows more about it.
On this point, I completely agree.
Softus said:
Bunch of nonsense.
Is it? Which bits are nonsense, Softus?
The bunch.
You didn't correct the poster who'd made a mistake about the function of the check valve.
It's not my job to correct every poster on everything they do, or might, get wrong.
Softus said:
Onetap said:
Do you describe yourself as an 'Engineer'?
That all depends on what you mean by those inverted commas and that capital letter.
You do call yourself an "Engineer", then.
And there it is - that third groundless assumption. Well done.
You're not a professional, you're not an engineer, you're not competent and never will be.
Deal with it.
The only interesting thing about that statement is that you appear not to believe it, and are just making a weak attempt at a snipe.
If an engineer is someone who, when asked for clarification, makes wrong statements based on tenuous assumptions, then clearly you're much better qualified that I am, and I'm entirely comfortable with that.
16 Mar 2007
Softus wrote
Bottom line: in the circuit in the diagram above, there is a benefit to using balancing valves,
You got it wrong here Softus .
We all make mistakes.
The man who makes none makes nothing. !
21 Oct 2004
You got it wrong here Softus.
You're right - I hadn't noticed. The error isn't what you thought - I edited that paragraph to change the polarity and messed it up. It was supposed to read:
in circuits other than in the diagram above, there is a benefit to using balancing valves
...or something like that - the point was that I was disagreeing with your introduction of balancing valves into this topic, because they weren't relevant.
19 Jun 2006
Essex
Softus said:
Deal with it.
I do believe it. It is the only reason that I can imagine for your abusive and derisive comments after I had provided a civil and correct answer to your earler question; "Onetap, I don't understand your suggestion to use balancing valves - why do you think this is necessary?"
It seems that I have inadvertently bruised your fragile ego by explaining that; a) balancing valves are usually necessary and
b) you were wrong
I've seen a lot of this and think you're probably suffering from delusions of your own abilities. Thirty or forty years ago, when the UK was a manufacturing economy, technicians or trainee engineers would typically be attending a technical college for 3 nights a week after work. No-one would do that now. Many technicians nowadays are carp, but they think they're good because they never meet and compare themselves with competent technicians.
8,000 posts, no common sense.
I have work to attend to.
21 Oct 2004
You simply replied with what I presume you believed to be a clever question, but it wasn't an answer, and it wasn't helpful.
Oh yes, I'm really fragile, me. :rolleyes:
Mm, that chip on your shoulder looks almost good enough to eat. ;)
Run along then.
19 Jun 2006
Essex
It just answered your question; remote circuits, no flow; near circuits, excessive flow.
Read some text books, they'll tell you the same.
You haven't explained why you think my answer is nonsense. You cannot.
Softus said:
Run along then.
And leave you pontificating your misinformed opinions to the unwary?
Do you get some gratification by pretending to be an expert?
21 Oct 2004
I don't regard a statement of the bleeding obvious as any kind of answer.
I think I'm more inclined to write one that read any more.
Nor do I need to. It's obvious.
Softus said:
Run along then.
19 Jun 2006
Essex
We're agreed on something, it's obvious that balancing valves are needed.
However, at the start of the thread you had asked;
Softus said:
Onetap, I don't understand your suggestion to use balancing valves - why do you think this is necessary? :confused:
You didn't know then why they were necessary.
It would seem that you have learned something from me, despite your best efforts.
This doesn't explain or excuse your ill-mannered posts. You will probably feel obliged to apologise when you have grown up a little, but I don't anticipate this happening any time soon.
A question for you, Softus, an opportunity to display your knowledge to your admiring audience.
With a heating system, you could minimize the amount of balancing required by designing the system as a parallel reverse return layout.
If you wanted to minimize the necessity for balancing in a HWS circulating system ( such as those shown in the Danfoss PDF documents posted by Balenza above), how would you design it as a reverse return system?
Answers and layouts on the back of a postage stamp.
Softus said:
Run along then.
Bye.
21 Oct 2004
We haven't agreed when balancing valves are needed, so I don't call that any kind of agreement. :rolleyes:
Incorrect - I didn't know why you thought they were necessary. These are two very distinct and different points.
Your stupid little opinion is noted.
Such an audience exists only in your head.
