I am in the process of planning my bathroom.
What started out as a basic change of suite is just escalating into more proposed work, however if it gets me to the end result without too much excessive cost then all is good.
I have ordered a steam shower bath cubicle thingy, which comprises a whirlpool bath section (with it's own pump for recirculation of water), and a shower section which has steam facility, overhead rainshower, extra hand held shower and 12 body jets. The quoted minimum water pressure is 2 bar.
Now I currently have a gravity fed system. So I am now aware that I will need to fit a pump which must be plumbed in to it's own unique supply to the hot water cyclinder and to the cold water cistern in the loft.
I am just weighing up my options now as my boiler has not been serviced since I first moved into the house (9 years ago). It was also never that clear how old the boiler was when I first moved in as I think I was spun a bit of a tail to how new it was. It still works fine although the outer casing is somewhat rusty and on of the knobs has broken off.
My hot water cyclinder is also somewhat precariously installed in the airing cupboard above the boiler. It is seemingly sitting on a couple of wooden beams that only seem to be held up by thin bits of skirting board on the wall. Yes I know I should have reinforced it along time ago. Nevertheless the water cylinder has a lot of greenish limescale (I think) or rust of some sort in various places. I am guessing that this may need replacing.
Now I'm also concerned about the flue as this is the concrete type piping that vents into the loft space and out through the roof. The piping especially in the loft seems fairly fragile and the joins between bends cracked. I do have a carbon monoxide detector functioning and fitted on my landing to be on the safe side but now want this looked at and upgraded too.
I guess I have a few questions:
1) Should I get my current boiler serviced, hot water cylinder replaced and flue fixed. Fit a pump via separate hot and cold supplies and plump in the shower steam unit. If this is the best option and I'm going to replace the hot water cylinder then should I be thinking of getting a bigger one. My concern is that with a pump I may run the hot cylinder dry.
2) Should I fix the flue and take the opportunity to change the boiler to a combi system. My concern here would be that the water pressure still may not be enough to power the rainfall shower and jets.
If I've asked anything that appears obvious or just plain stupid then please excuse my ignorance as I'm learning most of this as I go along.
I'd appreciate any constructive comments.
Thanks in advance,
Daz
Thanks in advance,
Daz
