Uplighter dimmable energy saving bulb wont fit
13 Mar 2010
Tyne and Wear
We have recently bought a uplighter of which the light bulb is on a dimmer. The problem is all the energy saving dimmable bulbs are too big and wont fit. Is there any bulb holder I can buy to get around the problem, or any other solution.
Thanks in advance
Steve
energy saving lamps don't work the same way as filament light bulbs or tungsten halogen tubes. They won't work in an ordinary downlighter if it has a dimmer not designed for energy saving lamps.
you could look for a downlighter designed to dim CFLs, I don't suppose it will be cheap. Another method is to buy several lamps, and turn one or more off when you want less light.
they don't work in an ordinary dimmable uplighter either
The CFL should be designed to be dimmed by an ordinary dimmer not the other way round....
"should be" :roll:
they work a different way
how much extra are you willing to pay for an extra dimming circuit to be built into the CFL?
that's between £7.87 and £10.92 each more than I paid for ordinary CFLs yesterday
Thanks for all the replies. I dont think I made myself clear ( typical for me! ). The uplighter is a room ceiling light. The energy saving bulb I have is made for a dimmer. The link to it is provided below.
http://www.toolstation.com/shop/Lig...+Dimmable+Spiral+T3+20w+BC/d220/sd3223/p24782
The bulb's in the link you provided are too big as they are also 120ish mm in length. I think this is roughly 15mm too big for the uplighter. I either need to find a smaller dimmable energy saving bulb or work out how to fit the existing bulb in the downlighter.
Thanks in advance.
Steve :D
Are you now? :wink:
So does the light shine upwards from it, i.e. as in uplighter? :D
So it's a downlighter now, i.e. where the light shines down from it? :lol:
Your best bet is to stop f*rting around with dimmable CFLs, which are cumbersome and tricky to match with dimmers, and install something like this: http://www.qwikfast.co.uk/catalogue/high-frequency-electronic-downlight-p-5016.html and replace the control gear with a dimmable one.
Its alright Steve....
I could see from JohnD's reply that he was confused.
You will struggle to find a smaller dimmable CFL for your fitting....there is a company called 'feelux' that may produce a slightly smaller dimmable CFL but I don't know the full spec...
By the way...if it is an uplighter, can't you just position it a little higher so that you don't see the tip of the lamp?
Cheers.
BAS.....'cumbersome'...maybe..but that sylvania lamp will work with ANY dimmer....the only problem maybe an underloading issue with a single lamp... :)
