Hi i tried to find this exact fault but couldn't and just need some guidance on where to look.
Have a upvc front door with a standard pull up the door handle to lock and then turn the key.
The problem is if i left the handle and lock the door in the frame its fine and the key turns, but if i check the door by applying slight pressure to the handle downwards the key wont turn and i have to lift up again ever so slightly.
It does this if i try with the door open so don't think its catching on the frame. I changed the door handles today thinking maybe the springs are stretched but it still has the same issue.
Could it be it needs a new barrel?
Any help appreciated
