Hi handle sometimes doesn’t spring back to horizontal after lifting up to lock door,any help on what to try ?
Thanks that’s why I asked here don’t want to remove the handle thinking I can fix it and it’s something elseI think you need @ronniecabers to answer...
My mum's backdoor has the same problem. Removed the guts of the lock and a spring had snapped in the main lock.
Sounds very much like the internal springs have broken. Depending on the lock type you should just be able to change the gearbox BUT just whip the handle off and check the springs for the handle, occasionally those break keeping the handle from returning properly ( my moneys still on the gearbox though lol )
Some of the older ones didn't, most new ones do though. The older ones relied purely on the springs in the gearbox to return the handle to its ' central ' position. Sometimes it's possible to put springs cassetes in the back of the older style handle to alleviate a 'floppy ' handle ... admittedly it's masking the main problem but usually its enough to get things working again
Can I ask if it’s the gears as mentioned what’s the fix ?Just search the likes of evil Bay for upvc door handle springs, there are various types so you'd need to see the different ones and determine if they'd fit you handle
