Urgent brickwork repair advice
Thanks. One of my main concerns is that the mortar is so fragile. I could just keep scraping and it comes out like sand.
So I could repoint like an inch all the way, but if the middle is like sand, what does this mean?
Do o just keep scraping it out and filling ever deeper voids or what?
A mate of mine is a pointer. I often work on the same site with him. He normally rakes out about an inch, dusts off and puts in a bedding joint and later points over that.
Im not having much luck getting quotes.
I have one quote which was to replace low level bricks that are damaged (at/near to ground level), and brick up small window, areas of repointing around the vicinity. That was £1k including materials (estimated 2-3 days work).
Another guy has let me down twice now to give me an estimate.
I also have tried to take off the paint, with limited success. I had a quote off a local company to clean off with a DOFF steam machine - £750 + VAT. Seems high. But Im not having much success getting it off myself. What would you do here please?
Well if it was me, I'd try a sample brick with either a wire brush type thing on my drill/angle grinder or paint stripper, no way would I pay what you've been quoted.
Think you can get it blasted but not something I have knowledge on.
Good luck
How are you currently removing the paint?
When my windows were replaced with DG, it left a ring of paintwork, where the original wooden frames had been over painted. What I used to remove it, was a wire brush in an electric drill. An angle grinder, fitted with a wire brush, would have been even more effective, but it worked.
Yeah I'm using a wire brush in drill now, in combination with more paint stripper chemical and a brick cleaner. It's working but the bricks will never be normal colour again I don't think.
Maybe once Ive got the brick repairs and repointing work done I'll consider having the whole wall rendered.
Is there a company near you that offers mobile wet blasting?
The blasting medium is often glass and the results are amazing. You'll be sick of your life after that lot!
John :)
John :)
Been looking and haven't found anyone yet.
Looked at a buying a sandblasting unit myself but they seem to need a hefty compressor to power them, so the pots themselves are quite reasonably priced but the compressor would be expensive. Also it seems the media is quite expensive at £25 per 25kg bag, and Im not sure how quickly it gets used up.
