Used c1 adhesive on porcelain floor tiles, will it be ok?
15 May 2013
Hi all,
I'm pretty new to the world of flooring. Managed to find some reduced porcelain floor tiles at wickes. 5 boxes of 6 tiles for £9. Tiles are 60cm x 30cm. I've put them in a small utility room where the floor is level concrete. I bought some mapei c1 tiles adhesive and got laying but since have read c1 is no good for porcelain to low porosity. Do you think if it will be OK or do I need to flexible polymer modified stuff to make it work properly.
Cheers
Hi all,
Cheers
You’ve got a good deal on those tiles, use the correct adhesive, a utility room will see a fair amount of traffic. If you are determined to save money, you could test it on a single tile.
