I need to provide an additional core to my central heating controller (for a separate hot water signal). I have some 1.5mm2 T+E, but obviously only need to use of of the two cores. What should I do with the second core? Should I cut it off and wrap insulation tape around the end, or use it in parallel to the first core, ie double it up?
I know that I could either replace the T+E with 3+E of install a double insulated single core, but I was hoping to use what I already had.
Thanks for advice.
Thanks for advice.
