Utility cupboard with boiler and switch board. What the right sensor detector?
22 Nov 2019
What the right sensor apart the carbon monoxide to install on the utility cupboard where we have boiler switch board and washing machine.
You're confused?
You can have all three, or none at all depending on what you trying to achieve.
There is no requirement for any detection, unless you are installing a LD1 system - which is a detector in all rooms. In which case the minimum is smoke detection in the utility. Heat and CO are optional.
