V4043H Valve working ok?
22 Oct 2013
Essex
Hi, the water if failing to heat in my cylinder vial the boiler/coil. When the programmer calls for hot water the boiler fires up and the zone valve (Honeywell V3043H) actuator moves across but water does not seem to get to the coil?. I opened the drain cock at the base of the Cyl, where the water feed should enter ? the coil after the honeywell zone valve but no water comes out?. There is hot water reaching a T junction in the pipes where the feed splits to the zone valve and a rad. The Rad heats up, but the zone vaves does not seem to pass water through?. could the coil be blocked?. The Cyl stat appears to work ok. Any help apreciated...Thanks
You are confusing me with your description of what you've done. Why not post a pic of the setup and get a more accurate answer.
