Vaillant Boiler Clicking
Nope, no filling loop there. So as per @Gasguru, we could now do with a photo of airing cupboard. We can advise further then.
Looking at the photos so far, tells me it’s an open vented system,not sealed. So I refer you back to post 5 by checking the feed and expansion tank (smallest of the 2) for water, but firing up for heating with no demand suggests a failed zone valve. Has this issue always been there?
Thank you.
I’ll get the ladder out tomorrow and head up there, shall report back on it.
When I reported that the heating and water was off, I did this on my app but went back to check the actual hive hub and it was still on there. Heating and water are now turned off, and it hasn’t happened since then (1 hour or so).
Still abit strange how the heater fired up (when hive was on) when the requested temperature was lower than the room tenperature
Need more pictures to determine the system.
Have a look below the Luxury flannels...there should be a pump...
And you might find it's a sealed system (I can't see enough pipes going up into the loft).
Ah, we have a pump where you mentioned. Could this be what’s clicking/rattling and all the above?!
You need top find out whether it's a sealed system (with a red vessel, pressure gauge etc) or a traditional open vented system...have a look in the loft for a small cistern around 500 x 300mm.
If there is sufficient pressure/water in the system then investigate the pump....those pumps are not great quality.
The front plastic hex "nut" unscrews. Then pull the nut gently out and it will engage with the impeller. Try spinning the impeller. You can then determine if it's seized.
With power applied you can feel the torque...perhaps the motors weak.
There will be a little water loss so have a cloth underneath.
Okay thank you.
The hive is off as I mentioned, it’s started making this noise again. I’ll get to the loft tomorrow and come back to you both
cheers
Hive is off, is boiler firing for heating or hot water? Is there any control on the boiler?
It’s the heating that is firing up
There are controls on the boiler for both settings, to increase or decrease the temperature (of the boiler and water in the boiler system), not the room temperature level
Hi.
I’ve just been in the loft, the water tank is half full, I’ll send pictures over now. There are water droplets coming from the area just above the red dot on the picture
Do these picture help at all?
thanks all!
