Vaillant boiler - does this look right?
Don't they both come on with a demand on the system version?
If the HW stat is turned up on the system boiler, the tap will appear even tough it is doing absolutely nothing.
On a system boiler the DHW stat should always be left fully off, unless you are using the Unistor and VR65.
When i first saw one i made myself look like a right halfwit by telling the customer that they had a combi :oops:
The gauge on the right seems to be quite low - my friend tells me the radiator in the bathroom upstairs is not working... and suspects this means that the pressure is slowly going down
I think this is what happened before - do you know of any way to give it a boost. The engineer was able to last time, I just can't remember what it was that he did.
2 grey knobs under the boiler that say 'closed'. Turn one then the other and the pressure will rise.
Increase to 1.2 Bar then turn off both knobs again.
Dave, that's really kind
Do you mean the two grey knobs to the side? These ones here on the left?
No,underneath the boiler. On the bottom of the boiler where all the pipes sticking out of it are :wink:
