Vaillant CH keeps turning itself on!
MrC
26 Apr 2006
Our 4 year-old Vaillant ecomax has recently developed a mind of its own, and has started turning the CH on at random times of the day, even though we have switched the CH dial to off/summertime use. Two months ago an engineer came and fitted a new DHW heat exchanger which sorted the problem for only a few weeks. Can anyone advise?
9 Sep 2005
Sussex
If the "aquacomfort" or warmstart is turned on this will cause the radiators to partially heat if the diverter valve is sticking.
26 Jun 2004
London
Now I wonder just why he changed the plate HE. Could it be dirt in the system??? I would have cleaned it!
The correct procedure would be to power flush the system which is what should have been done before the boiler was installed!
Just possibly the diverter is sticking due to that same dirt! They can stick even on a clean system though. I think the later ones are slightly modified to reduce sticking.
Tony
24 Jul 2003
London
They went through at least five "improvements". But I recently changed one of the latest type, which was as clean as a whistle :cry:
15 Apr 2005
Leeds
I've got a Vaillant 824E TurboMAX, the CH would stay on, switch on itself + then the HW wouldn't work whilst the CH was on. The diverter valve was sticking.
Ordered it from the web for approx £85 ;) (local merchants wanted approx £140) + got it fitted for £30.........10 min job.
All is working fine now..........i've heard it's a common problem with these boilers so good luck
28 Apr 2006
London
vaillant had a batch of boilers that were sent out with probs - i have one fitted but would never use them again -
Had the same fault, and it was the diverter valve, if you are paying for this repair it not a hard repair so be watchfull.
