- Joined
- 21 Mar 2022
- Messages
- 21
- Reaction score
- 0
- Country
I'm hoping from some sage advice, from you lovely people.
I have a Valiant Ecotherm 832 Combi boiler that was put in about 4 years ago. I'd just moved in, and the place had an old oil boiler that sounded like a jet engine, and an uninsulated hot water tank that was taking up tons of room. The plumber suggested the combi to replace the boiler and it would also let me get rid of the tank. I've been very happy with it, all is good.
However, the house also has PV solar panels, and was apparently using them to heat the hot water when they were generating, essentially free hot water. I hadn't realised this at the time, being new to solar, I just thought it reduced my electric bill a bit. Anyway, whilst it's not been an issue with the price of gas and electricity going through the roof I thought it might be a good idea to make the most of what I have, as essentially I only get paid for 50% of the electricity I produce and unless I'm at home in the day and using electricity the rest gets "wasted".
From what I've read on here it is possible to add a hot water cylinder to a combi, so that's good, but it seems people want to do it to get over flow rate issues to provide for additional bathrooms, that's not my issue. I have one bathroom and an ensuite, I'm more than happy for the combi to supply the hot water to the kitchen and ensuite, but as I'm doing the bathroom up I'd quite like to fit a power shower and a deep soak tub, both of which I feel would benefit from a nice large tank.
Circumstances mean the tank would either have to be on the same level as the bathroom (which is downstairs) or in the eaves just above it if I can find a shorter wider one.
So my question (sorry to ramble, but we got there) is should I be looking at an unvented system or an open system? Can I even have an unvented system on the same level? I've always known those as gravity feed but I guess they can be pumped? I have good mains pressure, so should it just be unvented on the same level, mains fed for top up with a pump for the power shower and a direct 22mm feed to the bath for a nice quick fill up? Also, any suggestions as to good well insulated tanks would be great.
I'd like to contact some plumbers once I have things a bit clearer in my head so that I can discuss it with them properly and see what they suggest.
Many thanks for any advice, suggestions or tips you might have.
PS. Happy to let the combi carry on handling the heating
