Got a problem with an ecomax 824 showing F23 code..
CH not circulating properly even though system pressure is ok and all rads vented..
HW cutting from Hot to Cold..
Suspect sluggish pump as Heating circuit not circulating correctly.. Pump is running though..
Display shows temp rising pretty quick when firing up then cutting out also some kettling noise from the heat exchanger..
Would a fault with the Ntc's cause this or is the Pump to blame?
