Vaillant ecotec 438 overheating on HW
23 Jun 2012
Nottingham
Hi all the vaillant ecotec 438 is overheating when HW is on
HW only - If flow set to 60c it goes up to 80c
It's fine on CH
When both CH and HW on together it will go up an extra 10c
Here's a video with it on HW only
Probably a secondary heat exchanger issue
apologies though it was a combi ,ignore my comment
Boiler does make a water gulping sound when I switch between HW and CH and some of the pipes making clanging noise too but 3 port valve is very far from the boiler up in the loft
Is this a new problem? Or could it have been going on for ages and you've only just noticed it?
Am I right in thinking this is a regular heat only boiler?
What does the dial with the tap symbol on actually do? Does it do anything?
A new problem.
Heat only boiler, that dial does nothing
Is It a sealed or open vented system, if sealed, check pressure is 1 bar cold, minimum, if OV, check that feed and expansion cistern in the attic is "full", around a 1/3rd or so.
I thought I remembered the name, it all goes back to this??.
You now have a 6M Wilo Yonos Pico, what mode/setting and power output and flowrate is it showing, you found the almost brand new UPS 3 full of crap, also the magnetic filter, have you checked/cleaned them out/.
Hahaha how you doing?
It's on constant curve highest setting.
Yes magnetic filter cleaned a few times and last time I added inhibitor to it and that immediately helped this new issue.
If it's working ok for CH but not HW to me that suggests that there may be is insufficient water flow when the HW only is on.
Is there a restriction in the HW circuit. Usually there is a balancing valve on the HW return, has it inadvertently been closed too much?
Anything happen just before the problem occurred, any work being done elsewhere, anything been changed?
Nothing at all
