Vaillant Ecotec Plus 832 Low Pressure
3 Jan 2022
I've recently moved into a property and the boiler has lost pressure. I've had a look online and it says there should be 2 taps to fill up the pressure. I cannot seem to find any taps below the boiler. Can someone please help? I've attached an image.
aD475zF
Looks like the two levers have been removed. Follow the silver ,braided, flexible hose ,to each end. Where it meets each fitting you will see screw head . Directly below the screw ,is a flat ended shaft. You need to put a spanner onto the flat ended shaft to turn 1/4 turn to open ,on both of them. When both are open ,water will flow into boiler to top up pressure. When done ,make certain both are closed ,back to their original positions.
Do you mean these circled in black? sorry I'm very new to all of this! I've tried turning those with some pliers but they don't seem to.
No ,not where you circled. There are 2 small screw heads ,pointing downward.
One is in-between the right hand black circle and the red knob.
The other one is to the left of the right hand black circle ,and further up( toward the top of your picture)
Ah yes I understand you now thanks! do you turn clockwise or counter clockwise?
Can't remember ,think it's anti clockwise as you look upward. And you really need a spanner rather than pliers. You don't want to" round off" the flats.
Boiler looks like the Ecomax? Just be certain they’ve not left it like this for a reason, as in fitted another loop elsewhere.
Thanks very much Terryplumb. We took the screws out and there’s a slot for a slotted screwdriver to turn them! Resolved
