Vaillant ecotec pro 28 F75 fault
If I can't hear the control board trying to fire up the pump, I think it's 5 attempts? but instead it immediately goes to F75 what would this point to?
CountryFan I suspect is being exhausted by your reluctance to move forward.
He works on these boilers I can imagine in auto pilot mode, picking his nose, thinking about holiday in an exciting land, and a lot more and still fix the defect without engaging the vaillant brain section
The sensor is very susceptible to debris, so changing it will only fix the issue temporarily. I would add a Magnaclean filter and then a cleaner solution like x800. After a couple of days run water though it discharging the waste. This took me an hour. Finally add inhibitor like x100. I did this a couple of years ago and no issues since.
  • Like
Reactions: DP
X800 is great cleanser with sting in the tail. I prefer flush through single radiator in turn with boiler running at low power for complete clear out of chemical else pump bearings can be compromised. Know this from experience
