Builder accidently cut through rad. pipe, draining water from heating system. Pipework now repaired and boiler filled, but when I turn heating on, boiler fires up for 8 seconds and then switches off. Could it be an air lock? If so, how do I clear it. I have discovered a key underneath boiler that fits two valves. One allows water to build up pressure (i've been allowing 1-1.5 barr) don't know what the other valve does. Also discovered a plastic rotating knob underneath at back of boiler that lowers water pressure when turned. Have played with these but can't get boiler to stay on. Hot water is fine.
