I have a problem with the hot water, basically the hot water will turn on the first time the boiler is switched on, then after that will either not come on at all or just heat up for a few seconds. boiler is a turbomax with green buttons. pressure is 1.1 bar. Reading through previous posts it sounds like it could be the diverter valve (green microswitch fitted) About 3 months ago the diaghragm was replaced as we had a similar problem.
Is the diaghragm in the diverter valve, and if it has why has it failed so quick ? The plumber who fitted the diaghragm won't come back to look at it so I'm stuck. Any ideas?
