Vauxhall astra wheel bearing
10 May 2020
I need a wheel bearing replacing on my vauxhall astra 1.9 cdti sri estate. Found online for £43 which I think is quite reasonable but various sizes on the thread size m22 or m24 How do I know which 1 to order. Thanks
Got to be the thread on the driveshaft......pop the wheel off and remove the driveshaft nut for measuring? Bit of a chore, I know......release the driveshaft nut with the wheel on the deck.
John :)
If it is the driveshaft end thread, perhaps a 22mm / 24mm open ender to see which slides over the thread diameter?
Yep, if there's enough visible thread.....not always the case with locking caps fitted or whatever.
John :)
Could it be that the thread may be different but maybe the splines are all the same?
I’m presuming it is a front bearing.....jumping to conclusions once again!
Maybe a cross refence from Autovaux or whatever would help, a reg number is usually pretty foolproof.
John :)
