Vauxhall combo (cigarette lighter)
Rob
14 Aug 2006
London
Has stopped working throughout the day, only receiving 130mV- at the stand(?) itself
Checked the fuse list and its listed with ignition and loads of other things that are working?
thanks
Hi why are you checking for current at the stand, do you mean the socket for the lighter,.. the cigar lighter will be separately fused from the ignition cct which is in the order of 50/60 amps, if you have a manual for the car you should find that the c/lighter fuse is rated around 10 Amps and may be o/c if the fuse is intact then check the 12v supply to the cigar socket if this is present then the element in the lighter may be at fault.
cheers :)
Hi Rob 884, you asked for help with your car lighter problem, please let us all know if my advice helped or not. :) cheers
Hi sinewave, just read your post so i decided to go and have another check.
You were correct that the fuse had gone. Although i did have to check everyone. Manual wasn't much help.
Anyway thanks for replying, had given up on it but now i can use my satnav and mobile charger again!
Thanks Rob
