i have a vauxhall zafira with a knocking noise underneath at the front of the car but only when doing low speed going round corners or over bumps can anyone help
More than likely the noise is coming from worn 'drop links' or 'stabilisers' which are part of the front suspension linkage. Very common to wear, they are cheap enough to buy and quick to fit so long as you have the correct tools, naturally.
John
Fitted to date this year: 7 sets of drop links (made of plasticene, I suspect), 2 bottom wishbones, 4 pairs of springs, 1 track rod end.
Thanks for the post back, and give us an update when you can.
John
Please can you tell me if you ever got the fault fixed? mine does exactly the same, I know it was agesssss ago but already tried several items to no avail
