Velux alternatives for glazed roof.
30 Apr 2009
Wiltshire
I would like to block up a rather useless window (a shed 2ft from it) in the wall of a lean-to utility room, and replace with some form of roof light.
I dont necessarily require it to be opening and am not keen on the "sticky uppy" look of velux windows. :eek: :LOL:
I did see whilst out and about a roof which appeared to have glass panels in it, sat on the rafters, with clay tiles either side. The glazing came down to the gutter. Imagine a couple of conservatory roof panels with tiling either side.
Is this achieved with glazing bars on the rafters, or something else. How would flashing be constructed for this type of arrangement?
Our lean-to roof is sloping with double roman (I think thats the right term) clay tiles currently.
Are there any companies/websites that deal in this sort of thing? My searches invariably bring up Velux windows. I cannot even find any pictures of this type of arrangement.
28 Oct 2005
Have you looked for glass tiles/ slates that would fit?
14 Sep 2006
Liverpool
You really just need to have a traditional roof-light frame made, and installed with lead flashing.
Although if it's a habitable space, it'll obviously need to be double glazed.
2 Feb 2006
Staffordshire
Using a Velux is the simplest and safest method of introducing light into a room via the roof.
How does the "sticky uppy" thing affect you when you are inside the building? The physical benefits of a Velux outweigh the aesthetic negatives.
14 Sep 2006
Liverpool
If you go for the 'Conservation' Velux, they stick up a bit less, and much more in-keeping with the traditional look.
Although I believe they can't be fitted at less than 35deg.
30 Apr 2009
Wiltshire
The same way having a neon pink front door, white plastic guttering, or a wheelie bin on the front lawn would :p
Thanks for the help guys.
