Evening all just after some help with the above fan..wiring method used is mains into a jb then from jb a switch wire to a pull cord and also from the jb a 4 core to a isolator and finally a 4 core to the fan..the fan only starts if i give the blades a small push..when the pullcord is pulled i get 240 between sl and n and then when pulled again 0 volts between sl and n so the switch is working as designed....the fan also wont turn of even after settingthe timer to the lowest time..the fan is the vent axia tile fan advertised as the qhietest fan around..i can only think the fan is knackered..any thoughts.. i took the fan out if the wall and switched it on and again no movement on the blafes
