I currently have what i can only describe as a 'normal' drill with hammer-action, but am having difficulty in drilling the 112mm or so diameter required for fitting a tumble dryer vent. Instead of using a diamond core bit (which probably wouldn't even work with my drill), i have decided on drilling a series of holes, and then chiselling and finishing up. Not quite as neat, i know, but seems a bit more cost-effective.
My question is: since Screwfix appear to have some good offers on SDS drills (namely Ryobi and Bosch), would this greatly help my cause or indeed be seen as a requirement when coming to jobs like this? The material to be drilled through consists of one concrete block and brick behind that.
In addition - by mistake a few years ago! - i already purchased SDS bits from Makro thinking they'd work with my existing drill, only to now find that they clearly don't. Since they were at quite a good price (JCB), i'm thinking it would be best to try and use these with a new drill. Or would buying a larger masonry bit for my existing drill have the same effect (also a JCB, so perhaps not amazing to begin with!).
Also as a final request, can someone please explain the difference between a percussion drill and a SDS one? I've just read on one website that a Percussion drill uses SDS bits which confuses me as to what the 'SDS-only' does?
P.S. I've looked at hiring and it seems pretty pricey. HSS have a SDS drill for one day at around £35! Admittedly, i haven't yet looked at the local places so they might be worth giving a shot. Though to be honest, i wouldn't mind buying a good drill that could be used for boring such holes as i'm sure it could come in useful in the future as well at some point.
Cheers
Cheers
