    Dismiss Notice
Vertical radiator loosing heat
Discussion in 'Plumbing and Central Heating' started by creative101, 2 Nov 2019.
  1. creative101
    creative101
    22 Nov 2010
    81
    Thanks Received:
    Aberdeen
    Country:
    So does this sound like a balancing problem?
  2. Sponsored Links
  3. John D v2.0
    John D v2.0
    26 Aug 2016
    6,315
    Thanks Received:
    876
    Country:
    No balancing is about flow this sounds like air getting in. Which is about pressure issues or corrosion. With inhibitor it must be pressure issues.
    When the system is fully cold does the pressure drop sharply? That would indicate too much air in the expansion vessel. When you try to bleed it is the system warm at all or do you bleed it stone cold?
    • Thanks Thanks x 1
  4. creative101
    creative101
    22 Nov 2010
    81
    Thanks Received:
    Aberdeen
    Country:
    the pressure remains steady around 1.6.
    I bled it when its warm as that when I notice it isn’t hot like the others. But there’s no air coming out.
    I bleed and let the water out in small amounts for about 10 secs and then it heats up fully. The rad has fours panels and the flow side always gets hot but not the other 3 panels unless I bleed out some water.
  5. John D v2.0
    John D v2.0
    26 Aug 2016
    6,315
    Thanks Received:
    876
    Country:
    What's happening in those 20 seconds if the bleed valve is open and no water or air is coming out?
  6. creative101
    creative101
    22 Nov 2010
    81
    Thanks Received:
    Aberdeen
    Country:
    water is coming out. But I let it out in small amounts. No air.
  7. creative101
    creative101
    22 Nov 2010
    81
    Thanks Received:
    Aberdeen
    Country:
    Just looked at the valves on the vertical rad and both valves are fully open.
    all the other radiators lockshields are only open about half a turn.
    Should the lockshield on the vertical rad which is the last rad / at highest point be fully opened or partially open?
  8. echoes
    echoes
    27 Mar 2007
    1,246
    Thanks Received:
    142
    Surrey
    Country:
    Does the radiator stay *hot* after you've bled some water through it, or does it slowly cool down again?
    Sounds like one side of the rad is heating from convection, and bleeding it just lets some more hot water through.
    Are you absolutely sure that both valves are open, and that water is circulating through the rad *after* you've let some water out?
    Does the return valve get warm at all?
  9. creative101
    creative101
    22 Nov 2010
    81
    Thanks Received:
    Aberdeen
    Country:
    the rad does stay hot... for about a week. The return valves is hot but not as hot as the flow. Both valves are fully open.
  10. Sponsored Links
  11. dilalio
    dilalio
    20 Mar 2009
    7,467
    Thanks Received:
    1,163
    Potters Bar
    Country:
    Turn other rads off, one at a time and leave for 10/20mins before turning off another one. See if this encourages flow through the vertical rad.
    If not then...
    Take the rad off and connect the valves together using a length of barrier (plastic) pipe, with inserts nuts and olives.
    See if you get decent flow through it.
    Report back with findings.
    • Thanks Thanks x 1
  12. creative101
    creative101
    22 Nov 2010
    81
    Thanks Received:
    Aberdeen
    Country:
    yes. This does help the vertical
  13. dilalio
    dilalio
    20 Mar 2009
    7,467
    Thanks Received:
    1,163
    Potters Bar
    Country:
    Then just balance the system properly.
    Close all rads except vertical rad and then crack open lockshields on other rads until they get hot... Some will only need an 8th of a turn open.
    If the vertical rad goes cold again after this, then you need to start looking at pump head and other issues... Piping perhaps.
    But try accurate balancing first.
    • Thanks Thanks x 1
  14. creative101
    creative101
    22 Nov 2010
    81
    Thanks Received:
    Aberdeen
    Country:
    thanks will do. Should both valves be fully open on the vertical?
  15. denso13
    denso13
    22 Jan 2007
    4,929
    Thanks Received:
    1,064
    Country:
    Yes.
  16. D_Hailsham
    D_Hailsham
    18 Oct 2007
    10,587
    Thanks Received:
    1,343
    Kent
    Country:
    The vertical distance between the ground floor and loft is irrelevant; a pump's "head" is just a way of measuring the pressure the pump produces.
  17. creative101
    creative101
    22 Nov 2010
    81
    Thanks Received:
    Aberdeen
    Country:
    Turned off the nearest radiator and it didn’t make a difference.
    Also with both valves fully open, I can hear Water trickling down the radiator. This isn’t normal right?
Loading...
Share This Page
