- Joined
- 13 Oct 2024
- Messages
- 13
- Reaction score
- 1
- Country
I live in a flat with a tiny kitchen too small to install a washing machine, and no doubt has never had one. I plan to install it just outside the kitchen, pipes that came with it seem just long enough, although in-time I might get slightly longer ones to make routing easier.
Under the sink there seems to a free doobrie to take a washing machine outlet, see red circle in picture 3. I'm guessing this is fairly straightforward; remove/unscrew plastic cap, pop on pipe (looks about the right size, see pic2). secure with a jubilee clip for safety. Although I'm slightly concerned about siphonage.
Of greater concern to an inexperienced fool like myself is the inlet, where mistakes get really messy, really quickly
My guess is, water off turning screw 90 degrees that's just behind the junction in pic1. Check it's off and remove pressure/some water by operating tap. Then I'm a tad hazy... I'm assuming I can't directly attach a T junction connector like pic4 directly, I'll need a very small bit of copper pipe? Would I be better off using plastic fittings?
Any advice very welcome as I've gotta do this soon, I'm outta clean undies.
