It very much sounds like it's a plumbing problem yet it's constant the only way to silence it is to switch the boiler off which instantly stops the noise.
The noise returns as soon as you switch the boiler back on and you can feel a constant vibration in the cold water mains pipe leading up to the Baxi Platinum boiler (where it's at it's loudest).
Turning the water off at the mains stop tap does not stop it either.
I'm going back on Tuesday and thinking of changing the diverter valve but it's a stab in the dark so I'm just wondering if any of you guys have had this problem?
Just to re-cap then, it sounds like a plumbing issue but my test so far are pointing to the boiler itself.
srvotech,
srvotech,
