Viesmann 100 Boiler Eating Pumpheads for fun?
Viesman obviously think system ok otherwise they would use it as there get out.
Might be down to pure bad luck or possibly (guessin here ) auto bypass on boiler not opening and pump , pumping away with no where to go.
He hasn't actually said Viessmann have been to the boiler. :roll:
Brand new central heating boiler combi boiler
I thought you could still have an open vented 100 combi, clearly not looking through the manual. :oops:
The 100 can be open vented. As the combi and heat only are essentially the same boiler, it can be argued that the combi can be used on open vent system.
The combi manual says sealed primary only.
This may come as a shock to you John, but some people don't always do what the manual says if it means they can get out the door quicker. :shock:
Last boiler I worked on had a faulty flue, faulty condensate, faulty bypass, no bonding on gas or water, system not flushed, controls wired up wrong, cylinder installed wrong, system not balanced, and the "UFH" was a 15 mm pushfit pipe in the 2m2 showerfloor without a manifold. :shock: Other than that it was ok.
Client did mention he was somewhat disappointed with the performance of his 30-odd kW boiler. :lol:
The only thing that surprises me is how some installations are completely and utterly effed up, and still work for years without people realising that there is something wrong.
Last boiler I replaced had been running on constant since the early 90's. Custard assumed that the light off on the timer meant the boiler was off as well. :lol:
B: "Didn't you have high fuelbills?
C: "Not really, £200 and something"
B: "Was that the summer or winter bill?"
C: "We pay by direct debit" :shock: :shock: :shock: :lol:
