Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I was going to have a Vaillant 831 fitted but the plumber who has just been around to quote suggested looking at the Viessman boilers 200 series. Anybody got any experience with these
if you have a normal house ie just rads the 200 series is a waste of time, its built for multiole zones ie hot water, upstairs rads, downstairs rads, underfloor etc the 100 series with weather comp would be much better if just a normal radiator system, quite a bit cheaper too
I wouldn't rely on a combi in my home and all I have to do is fetch bits from the van to fix them. However the only point I'll make that might be useful is this; Good, bad or indifferent, I can buy spares and accessories for any current model Vaillant at very reasonable rates from many outlets. Furthermore spares for discontinued models dating back to the 80's are available at the same outlets. I can also buy (if I choose) copy parts, recon parts, 2nd hand parts and so on.
All of this in less time than I can get a supplier to find the word Viessmann on his screen.
Veissmann 100 combi never had a problem with the new version, can always get intouch with technical and they come out asap if you have a problem also 5 year warrantee. Vailant on the other hand are not the company they used to be.
I've started using INTERGAS combi's just recently and i'm impressed with the product
