Villeroy Boch WC
14 Jul 2004
Can anyone tell me where a "Doughnut Ring" would be fitted on a Villeroy Boch cistern.
I had a compact Omnia Close coupled WC fitted and it is leaking between the pan and cistern and have been told that it should have had a Doughnut ring fitted.
TIA
fits over the syphon tube nut at the bottom.
More likely to be where the syphon fits into the cistern
Thanks, don't quite know why my plumber didn't put one on in the first place.
If yer donut's missing it'll only leak when it's flushed.
Looks like the king`s new clothes to me :confused: maybe it`s from his Throne
( can`t see a damned thing)
Thanks Andrew,
Its a bit expensive for a washer!
I expect the installer did fit it originally but perhaps its been distroted.
I dont see why a standard donought washer would not fit though.
Now why a little silicone sealant applied all around the joint should not work either if both surfaces are clean and dry.
Tony
The OP has been crapping down the garden for the last four years in anticipation of your reply, if you look at the date of the post.
I think that Andrew just saw it as a good opportunity to promote his bathroom shop web site !
Tony
