Vinyl Bubbling, DPM on concrete floor
25 Nov 2013
Hi Folks,
I recently replaced my bathroom floor and I have found it was bubbling, We kept it like that for 6 months then done away with it and decided to get a new one (Perhaps a dodgy installer). We went with another well reputable company paid for a full stick down and again its starting to bubble.
The original floor was Vinyl ontop of a tanked membrane as the room was originally a wet room. The floor itself is solid concrete slab on the ground floor.
I guess the concrete is just always going to have moisture which ends up underneath the vinyl causing any replacements to bubble.
So my question is would putting a waterproof epoxy ontop of the concrete cure this problem. So that the moisture and air of the slab cannot penetrate through the vinyl and adhesive?
When the old vinyl was uplifted the floor should of been left a week to breathe.
Can you post any pics?
If moisture in the floor still you will need a epoxy DPM. That has to go on a smooth surface with no adhesive on the subfloor. Then another layer of smoothing compound screed
Or you could lay on F-Ball Isolator, that would solve the issue quickly.
