Vinyl Emulsion not sticking to new Plastered Ceiling
13 Jun 2005
Monmouthshire
Recently had my Bathroom ceiling re-plastered for a new suite and tiles etc.
Used a 75% vinyl emulsion/25% water sealing mix. But in one small area it will not adhere/soak into the new plaster.
Would it be best to sandpaper the area and use an undercoat to seal the area, then re-emulsion when dry.
Or what other advice would you give ??
Thanks,
Can I use an oil based primer/undercoat over this, if not.
How can I sort the problem if a primer/undercoat is not the answer.
Sandpaper the bad area and re mist it.
Was it vinyl Matt or silk? Silk is not good for a mist coat and although vinyl Matt will work I'd always advise misting with a contract Matt. What is the finished coat going to be? Bathroom paint?
I might be wrong with the Emulsion, might not being Vinyl.
The Emulsion is Dulux easycare bathroom. Which Dulux say it can be applied thinned to new plaster followed by 2 thick coats.
