I do not know if there is a problem or the fact that the temperature outside might be causing the issue.
My Boiler seems ok but the problem is that you have to have the shower on really fine to enable you to have a warm shower. When you run a bath you have to turn the tap to almost off to get the water to come out hot.
Is there a problem with the boiler or is it because its minus 200 outside
Hope you can help
Hope you can help
