Vokera easi heat 29c Boiler loosing water/pressure daily?
g18
15 Sep 2022
Hi I wonder if anyone could help! I have noticed my Vokera easi heat 29c Boiler loosing water/pressure and now it is needing daily top up to 1.5 bar. When topped up everything is working fine. I have looked at other threads before posting and have checked all the following -
1 - To find the leak I have checked all radiator valves, pipework, out side pressure release valve and condensation pipes and the leak is 100% coming out of the grey plastic condensation pipe, even when boiler is in standby and not being used, it looses 1.5 bar per 24hrs approx.
2 - When the pressure is topped up to 1.5 bar and everything is working it does not go up to over 3 bar when heating on.
3 - There is air coming out of the tyre type air valve on expansion vessel and it says 1 bar of pressure.
Is there anything I could also check that may be causing this issue!? Many thanks for any help!
It sounds as though there may be a leak in the heat exchanger. How old is the boiler, it has a 5 year warranty. What is the serial number (it's on a data badge either on a sticker on the front of the case or beneath the boiler on the underside.
Hi THANK YOU for your quick reply! I have just checked warranty ran out 2021! Manufactured in 2016
Hi who would I book a fixed priced repair from? Vokera themselves?
Forgot to say! Just incase it points to something! Also when the hot water is running it seems to cut in and out? SO it gets hot as normal but then goes luke warm then hot again and keeps doing this when hot tap is running?
