a quick one for you all, possible diverter problem or low inlet pressure maybe but not sure yet.
inlaw has moved and hot wter flow rate is very low 4 on cup if two taps are on only one will work.
ive checked cold presure at only 8 on cup and think either the housold inlet pressure is to low or alternative boiler outlet is low.
the stop cock is behind kitchen unit and is unaccessable to use to isolate problem to actual boiler outlet pressure.
would i be right in saying its divertor problem or is can it the hot water flow rate be adjusted from inside teh boiler.
thanks
terry
thanks
terry
