Can some one advise on this, I have tried applying Ohms Law, but I am just getting ambiguous results.
Is it me ??
The car in question is a 1948 Ford Pilot converted from 6V electrics to 12V. But still uses the original Pos earth system with the Battery located in the Boot.
I therefore assume the resistance of the steel chassis is a factor?
If we assume the resistance of the 70 year old steel chassis from the battery + connection to the starter motor to be 1 or 2 Ohms, and the cranking current needed to turn over the 4 Itr V8 engine has got to be at least 35 Amps, surely that will result in some voltage drop through the chassis to the starter ?
Or are there factors, that I am not aware of ?
Is it me ??
