wall material to enclose porch
8 Feb 2007
We have a detached bungalow with an open porch area approx 3m x 1.1m. The bungalow roof (and gable end) overhangs this porch supported by the property wall on 2 sides and a brick pillar in the far (front) corner which shall be retained.
I want to enclose the porch area. Others have done this by just using UPVC frame and glazing ( the walls are not load bearing) but we are not keen on this. We would like to brick up the 2 open sides (and have small windows) but the narrow width precludes using a cavity block wall. The 2 main alternatives would seem to be a stud wall with internal insulation (and vapour barrier etc) or a single block wall with external insulation like Kingspan ( the external finish will be stone cladding / internal finish to plaster).
Which method would allow the best insulation (u value)? Are there "special" lightweight insulated blocks for this type of job ( I read somewhere less dense blocks have better insulation values). Any better suggestions? The enclosed porch will be heated so the aim is best insulation value for a circa 200mm thick wall to allow a finished internal width of 0.9m
If the heating is connected to the house system then building regulations will apply, and that will determine what walls to build.
I built my porch walls from 4x2 stud work, with 100mm Celotex type insulation within the studwork, and 25mm Celotex type insulation across the inside. 5" of Celotex is adequate for a roof, let alone a wall, and the foil provides a vapour barrier. I then used plasterboard on the inside, and OSB, breather membrane, battens and cedar cladding on the outside.
you obviously have a desire to heat it, but why? most porches aren't heated, and as woody says, it gets difficult regs wise.
Just enclosing it will make it seem very much warmer
Thanks for replies.The heating will not be connected to the house. It will be a standalone electric rad switched on from the porch. I think that satisfies the regs (or use to). GTH's solution seems a good one, what thickness/grade OSB did you use? Would Marine Ply be better?
I used 11mm, I think. There's no need for anything more expensive than that; it's only to provide rigidity to the frame.
