Wall panel advice
18 Mar 2005
We are putting a shower cubicle in and have decided to go for wall panels instead of tiles so that we have less grout etc.
There is a place not too far away that specialises in pvc panels. I have them the details of what I needed and they recommended the following...
2.4m X 1m X 10mm hollow panels X 3
The shower base is 1000*800
The room is 2.8m high.
I also want to use some matching board as a splash back behind the sink. The width of that area is 1280.
So on to my questions...
They said that the hollow board is better as it doesn't have any wood to rot etc. However another place told me that the hollow isn't as good as when you tighten the frame on our screw the fixings for the shower in place, you pull through it easily. Which is better? Hollow or ply backed?
The shop recommended that I just go to 2.4m high in the enclosure and leave the to section of the wall painted. Finishing off the top of the panel with a silver trim. However I'm thinking that I might be better to go all the way up. What are your thoughts on this?
Watching a video online (dangerous I know!) It suggested that the 250mm wide panels were better for fitting in the shower than the 1m wide panels. Obviously the 250mm wide ones need more joins but are supposed to be fully waterproof on the join. What do you find it better?
Thanks!
Leave a painted area around the top, horizontal joins aren't good. PVC (hollow) or ply are fine, either can be affixed with silicone, no need really for screws. The laminate boards wont rot, but will cost a lot more in material and i would charge more for labour. I would also opt for the wider panels, the joins are visable, more suitable for a ceiling.
i'd personally avoid the really cheap hollow cladding if it’s your main bathroom... the better quality PVC/composite panels feel much more solid and the finish looks cleaner long term. The main thing is getting the install right: flat dry walls, proper adhesive, and good sanitary silicone on every joint/corner. Wider panels usually look more premium too because you get fewer visible joins. Companies like Revetement Agro do some decent PVC panel systems worth checking out
Purchased mine online ,£35 a sheet .
You can get some at 2.6m for higher ceilings .
The only fixings in my shower is the metal upright holding the glass so fixings are not a problem .I used on three walls .The corner and shower base trims should be bought from same supplier .
I've used both hollow and solid. I've no real preference but did find with the white hollow ones we used on our ceiling if the light reflects in the right way you can see the lines in the material where the hollow core webs are, I suspect this is due to them being white and on an angle so they catch alot of light at different angles, the ones fitted vertically are fine.
Ive never had an issue screwing enclosures through hollow boards but I can see how you would if your heavy handed.
The silicone on the enclosure will do 90% of the holding the screws are just to get it flush against the panel whilst the silicone goes off so don't need ramming home as tight as possible.
